ALL Logs
A project log for Little cloud
a bedside lamp that is also an alarm
marceauperrinmarceau.perrin 05/30/2024 at 09:240 Comments
March 1, 2024
Project commencement: plan and guidelines to follow
Reflection step 1: creation of the PCB either pre-assembled or self-assembled, knowing there are about a hundred components
March 3, 2024
Begin reverse engineering the PCB without having prior knowledge on the subject
March 9, 2024
Completion of the electrical schematic of the PCB after ~10 hours
March 13, 2024
Finished component placement on the PCB
March 17, 2024
PCB and assembly completed, cost $33/2 PCBs
Progress on the other electronic part of the project with the ESP32
March 23, 2024
PCB does not work after checking each component
March 31, 2024
Continue research and start thinking about a Plan B
April 5, 2024
Begin coding the ESP32: Game of Life + LED control
April 19, 2024
Resoldering the PCB because it was not done properly
PCB resoldered
PCB still does not work
April 23, 2024
ESP32 broken, need to find a new idea
May 9, 2024
3D model design
May 23, 2024
New code + acquisition of new components
May 26, 2024
Final 3D printing and prototyping, and final assembly
May 29, 2024
Presentation + filling out Hackaday
