This projected was kindly supported by JLCPCB which is a PCB manufacturer trusted by 5.4M engineers worldwide. You can get high-quality PCB prototypes for just $2. If you use the following link to sign up, you can get up to $80 coupons: https://jlcpcb.com/?from=matthias
