The goal of the project is to create a card that can be kept in a wallet, without exposed components that are easy to break off. The target thickness is approximately 2.5 mm determined by the liion cell. The way to achieve this goal is to use two sandwich-shaped PCB glued together. The components between the layers will be safe. Parameters: -ATmega8 processor -LCD 84x46 points -Piezo speaker -4 action keys -2 function keys -3v lithium cell power supply -ISP port for programming Things done: -Functional prototype. -LCD test program demo. To do -conversion to LiIon and charging system -better sound system -additional SPI memory -write some games <div class="video-container"><iframe style="width: 500px; height: 281px;" src="//www.youtube.com/embed/eNE2NQ8thBE" frameborder="0" allowfullscreen></iframe></div>
Stephen Harrison
rahmanshaber
Chromico
