 Features & Components
ARPoLan combines several powerful components to deliver its impressive capabilities:
藺 Getting Started
I designed the PCB for ARPoLan using Altium Designer, creating a simple yet efficient two-layer layout. Here’s a breakdown of the components used:
The communication between the W5500 and the Atmega32u4 is handled via the SPI protocol, ensuring quick and reliable data transfer.
 Schematic
The PCB for ARPoLan was designed using Altium Designer, featuring a two-layer layout optimized for compactness and efficiency. The board integrates all necessary components, ensuring reliable connections between the Atmega32u4 and the W5500.
This setup will enable SPI communication between the Arduino Pro Micro and the W5500 Ethernet module.
 Usage
First Code: Local Rubber Ducky The first piece of code transforms ARPoLan into a local Rubber Ducky. The Atmega32u4's USB HID capabilities allow it to act like a keyboard or mouse, injecting pre-programmed keystrokes into a connected computer. This was a fun experiment, though I refer to it as the "bad idea" code due to its potential risks.
Second Code: ARP Spoofing Next, I tested the ARP spoofing code. This script injects malicious ARP packets into the network, leveraging the processing power of the Atmega32u4 and the network capabilities of the W5500. While not overly powerful, it demonstrated the device's potential for network security tasks.
Third Code: Network Scanning The final code was for network scanning. By sending ARP requests to all IP addresses within a specified range, ARPoLan could identify active devices on the network. This functionality is crucial for network monitoring and penetration testing.
Code & PCB
If you're interested in building this project, the code and schematic are available on GitHub. Simply visit the GitHub repository to download the necessary files. If the project gains attention, I’ll open-source the PCB files as well. Feel free to test the code and share your feedback or improvements.
GitHub repository: github.com/cifertech/arpolan
 Special Thanks to Our Sponsor: JLCPCB
No project is complete without the right tools and materials. That’s where our sponsor, JLCPCB, stepped in to provide essential support for this project. JLCPCBis a leading provider of high-quality printed circuit boards (PCBs) and PCB assembly services.
Simply head over to jlcpcb.com, upload your PCB design files, select your preferences, and Your custom PCBs are on their way to you in no time.
if you sign up using the link in the description below, you’ll receive a $60 new user coupon.
WebsiteJLCPCB Official Website
 Conclusion
Creating ARPoLan was a fascinating journey into network security and hardware integration. From designing the PCB to writing and testing the code, this project showcased the potential of combining simple yet powerful components to achieve sophisticated functionalities. Stay tuned for future updates and enhancements, and don’t forget to check out the project details on my GitHub. If you have any ideas or suggestions, I would love to hear them!
