Strength Test, Good News
A project log for Strain Wave Gear Robotic Arm
Mostly 3D Printed Strain Wave Gear Robotic Arm
jared-fensterJared Fenster 07/19/2024 at 04:560 Comments
I tested the Joint up to 6.26KG at 33cm distance (20.26 Nm), any higher, motor stalls. I am assuming there is a lot of friction in the planetary gearset, I will be working on that.
Super happy with the fact the FlexSpline Teeth no longer skip!
