I have just found out that the Moteus r4 has a connector for an additional encoder. If this works, I will not need to run the a cable for each encoder down the arm. This would also simplify the coding required.
I will be testing this later today once the adapter arrives.
The photo below is the current design for the first two joints that I'm currently building.
