4 Joint Designed and tested
A project log for Strain Wave Gear Robotic Arm
Mostly 3D Printed Strain Wave Gear Robotic Arm
jared-fensterJared Fenster 02/19/2025 at 04:210 Comments
After a few weeks of designing and testing, I've finished the 4th joint design. The entire Joint should be up and running this weekend. Thankfully this will be the last joint that I need to design as the next two joints are exact copies of this one. This joint was super difficult as I had to achieve everything the last joints could in a smaller volume. The biggest issue was making the joint smooth enough for the tiny input motors to be able to use.
