Hey everybody,
I'm excited for this update because I finally have some useful boards to show you, Check them out;
On the left is the power regulation subsystem and on the right is the USB interface subsystem. Now all I need to do is solder the appropriate parts on to each board and I will be ready to test them and see if my alterations have the desired effect. In addition to soldering and testing these boards I have several subsystems that I have yet to layout or mill, as well as several parts that need to be ordered. I'm finding that the aspect that I am least comfortable with is putting together a BOM for the parts needed. Luckily I will get plenty more practice before this is all over.
Till next time,
-Eric
