My objective is to build a functional Voight-Kampff machine from the classic Sci-Fi Movie Blade Runner.
Leon's Voight-Kampff test
Rachel's Voight-Kampff test
Currently, I'm working on developing the software, integration of sensors and the actual body of the machine.
My plan is to exhibit this project at the Chicago 2017 Maker Faire.
I have much of the mechanics (arm raise, extension, and rotation of the eye sensor) worked out using servos and micro-controllers.
My current design calls for using a Raspberry Pi as the central processor for the VK. The sensors that I'm currently working on integrating are:
- Metexis MLX90614 Non-contact Temperature sensor (for Blush response)
- Raspberry Pi NoIR Camera Board v2
- using software adapted from PyGaze to measure pupil dilation/constriction
- Separate hand held module for test
subject containing:
- MAX30100 pulse ox sensor
- Galvanic Skin Response Sensor
I aim to have it all contained in the classic Voight-Kampff machine with read outs from the sensors going to the 3 separate monitors (and the 2 LED Bar Graphs).
