Features and Benefits
•Flexible input powering options: Power hub from either USB-C or DC.
• Anything in DC: Internal Voltage Boost Circuit Input allows input voltages of 9V.
DC to 24V DC, any polarity. Even power the hub from an old laptop power supply.
• Full output voltage range: No voltage blindspots, USB-C outputs from 5V to 20V,
regardless of input.
• No reboots: On-board chip manager for each port ensures no reboots when new
devices are added.
• Chainable: Daisy-chain units together to expand number of available ports
• 24V DC output: 1 x 24V DC output port makes it daisy-chainable
• Intuitive lighting system: USB-C output ports change to green when PD/QC
protocols engaged.
• Flexible output options: Each USB port delivers PD-Equipped USB output.
Change to specific DC voltages with barrel with Step-Up USB-C to DC Powertips.
• Chain devices: High power to allow stable chaining of multiple devices from single
USB port with Crazy Chain Mk2.
• Isolated outputs: 7 isolated ports for noise-free operation [Silent Alchemist only].
• High power per isolated outputs: 20W per isolated port [Silent Alchemist only].
• Macbook / Laptop charging: One 100W high-power port, charges even Macbook
Pro. * Silent Alchemist only.
Stefan Wagner
UNIVERSAL-SOLDER
link is broken, the correct one is https://www.kickstarter.com/projects/myvolts/the-alchemist-power-anything-anyhow-anywhere
