I just tested one of my green boards with the latest STM8 eForth 2.2.20:
- the improved e4thcom support works great, even though the communication uses the DP segment
- #require loads aliases for unlinked words from the folder out/DCDC/target
- even loading Manfred Mahlow's STM8 eForth VOC extension, which patches the core, works without problems
The packaging method with automated builds (Travis-CI) used in the W1209 data logging thermostat project works well, and I plan to use it for providing pre-build "programmable power supply" binaries.
