Boost converter update
A project log for Ultimate head lamp
Ultimate head lamp
lion-mclionheadlion mclionhead 06/23/2024 at 00:070 Comments
Finally replaced the SEPIC converter with a much smaller boost converter & smaller switch.
The mane problem with these MHPS2283 switches is accidentally turning them on & killing the battery so they always need a protective cover.
The next big problem is the EVA foam not gripping enough.
