Finally replaced the SEPIC converter with a much smaller boost converter & smaller switch.
The mane problem with these MHPS2283 switches is accidentally turning them on & killing the battery so they always need a protective cover.
The next big problem is the EVA foam not gripping enough.
lion mclionhead
