Features:
- RJ45 connectors for fast and stable connection.
- Plug and play system.
- Configurable to acquire 5/24V PNP and NPN inputs.
- 5/24V selection for outputs.
- Each input or output connector also carries the 5/24V POE-style power supply.
Protections:
- Reverse polarity protection.
- Self-resetting fuses for each power supply.
Outputs:
- Full 5 Axis Step/Dir/Enable control outputs.
- 24-5V Outputs – Spindle, Mist Coolant, Flood Coolant, Dust Extraction.
- 3 x 24-5V Auxiliary outputs controlled by additional M-codes.
- 0-10V or 5V PWM outputs for Spindle VFD and laser module.
- CW/CCW/security enable for spindle VFD.
Inputs:
- 5x Closed Loop Stepper Motor/Servo Alarm Inputs.
- Opto-isolated inputs for DOOR/PROBE/HOLD/START/E-STOP input signals.
- Opto-isolated inputs for all limit switch input signals (Mechanical and Inductive limit switch compatible).
- 4x Opto-Isolated auxiliary inputs.
- An independent input for override vac output.
Firmware/Software Compatibility:
Connectivity:
- USB.
- Ethernet.
- SD Card.
- Auxiliary USB.
- I2c connectivity for external plug-in communications.
Example Driver Adapter expansion
Relay module for split 4 Neuron-1's outputs in protected outputs with fuses
5/24V PNP/NPN compatible inputs
Cortex Automations
Michele Perla
hms-11
Woah I love this, particularly the better closed loop integration. MKS/BTT servo42D/57D's are so cheap there's no reason no to but I rarely ever see it well supported by controllers. How can I help development? I can make my own PCBs at home with full mask and silkscreen, shit programming ability, FDM/resin 3D printing ability. How can I acquire a set of PCBs?
