• 5/14/24
    nb22245506/11/2024 at 14:00 0 comments
    -The apple slicer had to be redone because of sizing issues (from 18cm to 13cm in
    diameter, struggled with the openings on the side.
    -I profited from the redesign to add the final touches to the cap, in that case a handle that's curves to avoid any discomfort or injuries
  • 5/4/24
    nb22245506/11/2024 at 13:43 0 comments
    Finished the apple slicer cap design, need to test out the prototype, then modify it to better fit just in case, need to add a handle.
    Use the measurement of the apple slicer for he diameter of the cap by itself, with a high tolerance to allow for a snug fit. The gaps on the side are used to slot in the cap by taking advantage of  the indents of the apple slicer.
