Finished the apple slicer cap design, need to test out the prototype, then modify it to better fit just in case, need to add a handle.
Use the measurement of the apple slicer for he diameter of the cap by itself, with a high tolerance to allow for a snug fit. The gaps on the side are used to slot in the cap by taking advantage of the indents of the apple slicer.
