The hardware side is mostly functional by now. We're still going to make a third version with all the issues ironed out, but now we can focus on writing the algorithms to make it into an actual line-follower.
The software stack
The robot is controlled by ESP32-S3, a powerfull microcontroller with WiFi capability.
It can run in standalone mode, with a PID controll loop using data read from the sensor.
The ESP32 also acts as a web-server, and by connecting to it from a browser we can have a big control panel on our computer.
This control panel is connected with the ESP32 via webSocket, so all measured data is transfered in realtime and a lot of the processing can be done on browser side in Javascript
Control panel features
- Adjusting parameters in runtime
- Current and PID data displayed in a line chart
- Map of the robot's track - calculating position from encoders
- Manual control override - drive with keyboard
To Do:
The software for this robot is nowhere near done yet.
Most importantly we need to implement the PID control loop to make it follow a line, but there are other features we want to make.
The displayed map should basically have a scan of the track done by the robot's sensor, along with other visual data.
We also want to make the algorithm more advanced than simply following a line, for example handling intersections etc.
