Status: 22 June 24
A project log for ePiPod
MP3 player with an e-paper screen, based on the Pi Zero 2 W
drhatchdrhatch 06/22/2024 at 21:410 Comments
Log #1
Here is where the project stands today (22 June 24):
I have assembled the PC board, and it works as expected. This version was built from the gerbers (and BoM) that are attached to this Hackaday project.
I have iterated the case files a couple of times. The most recent version I fabricated was mostly acceptable, but could be improved with some minor modifications. I made those modifications, and the .STL files are attached to this project.
I am currently fabricating the case files according to the attached files, but I have not received them yet.  (I expect them to be very good, if not perfect.)  I will update the project once I use them to assemble a unit.
UPDATE: The Rev3 (current) case files are acceptable.
SOFTWARE:
The software is stable, and works well.
All source files are posted on github at: https://github.com/delhatch/PiPod_ePaper
