I have finally achieved an MVP! There are certainly more opportunities for optimization and improvement, for starters:
- Improving the timing and motion detection to stabilize the characters better
- Improving the user interface for more sophisticated functions using the push buttons as inputs
- More sophisticated animations
- Creating a function for updating/adding phrases
- Increasing the character alphabet
- Current options are A-Z, 0-9, [space], [period], @,!, and ?
Nevertheless, I can get the card to display my website "DTWPROJECTS.COM". Unfortunately, rolling shutter frustrates the effects to a certain extent (I had to pull out an osmo pocket and turn the shutter speed as low as it would go - 24 fps).
I had to work around some faulty issues with the X axis gyro I was sampling to detect up and down motion. I was able to get around the faulty gyro by switching to the Y gyro. It's slightly less effective but seems to work well enough. I may test with another gyro but this iteration should suffice for displaying contact details. It's probably not going to win any prizes but I can now officially consider this a business card :)
