Release v1.6.1
- Improved button handler
- Using Low Power Manager (LPM), draft
- Green LED shows state: dark LED CPU is in STOP2 mode
- After startup the USB blocks the LPM, you have to plug in/out the USB
A project log for 4TH Calculator
A small pocket calculator for programmers and engineers, a mix between HP-42 and HP-16. Fully programmable in Forth.
Release v1.6.1
