Genbook Rk3588
The open-source high-end ARM Laptop
Innovation Without Limits, Leading the Future
Public Chat
Do you want a laptop that combines performance, portability and open-source? Do you want to own a computer product that can be DIY? The upcoming Genbook Rk3588 not only meets your basic computing needs, but also provides an ideal platform for those who love the freedom to explore and create technology.
GenBook-RK3588 is an open-source laptop with Rockchip's RK3588
This powerful CPU integrates 4 Cortex-A72 and 4 Cortex-A53 cores and 4 Mali G610 graphics cores. An integrated NPU unit with 6 TOPs computing power can give local machine learning tasks a meaningful boost. This popular new chip gives users the option of many popular open-source operating systems, including Ubuntu, Debian,and Armbian. There was a Hackaday post earlier about this project:https://hackaday.io/project/196668-genbook-rk3588
Current Status
The hardware and software development are almost finished. The software and hardware of the project have been completed, so the technical documents have been presented on the open-source platform.
Now I am happy to share that there is a pre-launch page on CrowdSupply in case you are interested ingetting a kit: https://www.crowdsupply.com/polykybd/polykybd
Overview
GenBook-RK3588 adopts a design approach of a System on Module and motherboard, which facilitates future upgrades and developments.Users can also install higher-performance WiFi modules and bigger 2280-size M.2 NVMe SSDs. And if you need more ports, the accessibility of UART, I2C, and a 50-pin FPC interface will allow you to modify your laptop however you can imagine.
  • instructions of Genbook RK3588
    TMJS_OPENSBC07/02/2024 at 09:35 0 comments
    GenBook-RK3588 is an open-source laptop with Rockchip's RK3588 at its heart. This powerful CPU integrates 4 Cortex-A76 and 4 Cortex-A55 cores and 4 Mali G610 graphics cores. An integrated NPU unit with 6 TOPs computing power can give local machine learning tasks a meaningful boost. This popular new chip gives users the option of many popular open-source operating systems, including Ubuntu, Debian, and Armbian.
    GenBook-RK3588 adopts a design approach of a System on Module and motherboard, which facilitates future upgrades and developments. Users can also install higher-performance WiFi modules and bigger 2280-size M.2 NVMe SSDs. And if you need more ports, the accessibility of UART, I2C, and a 50-pin FPC interface will allow you to modify your laptop however you can imagine.
    Powerful and Flexible
    Performance
    • 8-Cores ARM 64bit processor
      RK3588 is Rockchips's new-gen flagship AIOT SoC with 8nm lithography process.Equipped with 8-core-64-bit CPU,it has frequency up to 2.0GHZ.Intergrated with ARM Mali-G610 MP4 quad-core GPU and build-in AI acceleration NPU,it provides 6Tops computing power and support mainstream deep learning frameworks.The powerful RK3588 can deliver more optimized performance in various AI application scenarios.
    • Three screen display capability
      GenBook-RK3588 has powerful display capabilities and can achieve three screen simultaneous or different display functions using external HDMI and TYPEC interfaces
    • Large capacity memory support
      GenBook-RK3588 supports a maximum of 32GB of ram and adopts a dual channel 32-bit structure, which can maximize memory utilization. Based on powerful memory support, laptops are very suitable for localized application software development, virtual machines, generative large language models, general-purpose servers, and other scenarios.
    • Powerful AI reasoning ability(single threaded)
      GenBook-RK3588-AI is a free and open source repository containing a series of AI demos. Developers can quickly deploy AI models on GenBook with reference to demo to improve work efficiency.
      Mission Scenario Model CPU speed(ms) NPU speed(ms)
      Classification ResNet50_vd - 33
      Detection Picodet 162 112
      Detection YOLOV5-s-relu - 57
      Detection YOLOV8-n 192 119
      Character Segmentation PPHumanSegV2Lite-Portrait 133 43
      Face Detection SCRFD-2.5G-kps-640 108 42
      Face FaceRecognition AdaFace/ArcFace/CosFace(R18) 81 12
    Software
    • WPS Office
      As one of the best Microsoft Office alternatives of 2021, WPS Office is fully compatible with main Linux distributions, including Ubuntu and Linux Mint. Download now to try the latest features in WPS Office for Linux. Writer, Spreadsheet, Presentation, and the PDF Toolkit can help you solve issues in viewing and editing common document types. Meanwhile, the small but feature-rich PDF toolkit can help you convert PDFs from and to Word, Excel, PPT, and image files with ease.
    • MPV
      Based on the powerful video decoding capability of RK3588 and the system optimization work of the GenBook team, the laptop can currently support simultaneous decoding of four 4K H.264/H.265 videos.The ubuntu system uses the following command to install:
      sudo apt-get install mpv
    • Vscode
      Visual Studio Code is a free coding editor that helps you start coding quickly. Use it to code in any programming language, without switching editors. Visual Studio Code has support for many languages, including Python, Java, C++, JavaScript, and more. Ready to get started? Check out these introductory videos or check out our coding packs for Java and .NET.
    • Qt
      Traditional embedded application software development requires the use of cross compilation environments. Genbook's powerful performance supports local development of embedded application software, drivers, kernel compilation, and file system creation, effectively solving various third-party package compatibility issues in cross compilation environments.
    • Kicad
      KiCad is an open source software suite...
View project log
