You can now drag components that have wires connected to it, and the wires will follow. This is very useful when you want to make small tweaks to the placement of a component.
This is the first version of this feature. And for now, it only changes the endpoint of the wire. I'll create another version soon where the whole wire will adapt as you drag a component, which will be even more useful.
