Enclosure for Bosh BME688 development kit
3D models and files to build an enclosure for the Bosh BME688 dev kit
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Bosh doesn't provide the enclosure for the BME688 development kit. CAD design with dimensions and 3D model are also not available. I think the enclosure is a requirement if you need to sample the air or gases on the move. I designed and built this enclosure because I needed to sample during extended time in different environments where USB power is not available.
Al the files and instructions are available at the GitHub page.
Thank you so much.
Enjoy!
Fabio
