Aidan has continued working on Walker since the last post. By using a Cocoa Pod, he was able to import the Particle SDK into the app. Now, he can access the devices on his Particle account using his login credentials! This is a big step in the project because we now can make the app and hardware interact together.
Next steps:
1) Add login, create account, and connect particle account segue screen
- this also means we must figure out the way in which we want users to be guided through the "connect to their particle (the attachment)" setup when they first purchase the device
2) Add a JSON file as a database or purchase a Raspberry Pi to setup as a server for a JSON file database
3) Add Particle commands to the application's buttons so the app has functionality
Check back soon for updates!
Aidan Draper
