I was inspired by PCB business cards a few years back but I am not an electronics engineer. I can make simple PCB designs but that would send the wrong signals. I admit, I was even a tad jealous, wishing I had something equally unique. Fast forward a few years, I found myself designing an old school paper business card. So I had an idea of making a business card according to my own expertise: in microfluidics.
I did not seek perfection. Instead, I wanted to make it quick and dirty, resource friendly (using old/expired materials) and learn something along the way.
Perhaps in the future, I would like to try some microfluidic concepts, such as droplet generators, sorters, valves etc. Even an embedded system with a PCB attachment is a possibility. Please, feel free to join me :)
Details
I had to reupload the video with some personal info blurred. You can find the old link below, which I will remove later at some point. New video:
Design your credit card in a vector graphics format. I used Inkscape. You can take your existing designs. Convert it into paths. Convert lines into 2D objects (squares, circles etc.). Basically, make sure that everything is a 2D shape with no strokes. No need to design the channels etc. at this stage.
2
2D to 3D design
Import the SVGs into your CAD software. I used FreeCAD. Extrude everything by a defined length. I also made a quick macro to refer the extrusion length to a spreadsheet value. That way it is more parametric and you can easily update it. This value is the depth of your visible features (text/logo/QR code).
3
Card Design
For the printed only version: Join (union) all those features. Design a prism (thick paper card) and subtract those features. The card needs to be thicker than the features!
Features should leave empty pockets on the card.
For the PDMS version: Join (union) all those features. Design a prism (thick paper card), add some rims/walls* and add those features on the surface. The card needs to be thicker than the features!
Features should extrude on the surface of the card.
* this piece will be a mold for the PDMS. It should be a container to contain the viscous PDMS until it cures. That's why we need the walls.
https://8171check.com
