Raspberry Pi Zero W - USB-Ethernet
A Zero connected only through one cable
0 followers
Turns out, this is hard since all the drivers are gone. So here are my steps to make this work anyways.
Basically, follow this guide. The Driver that makes the USB device into a network device under windows is the most important bit https://www.factoryforward.com/pi-zero-w-headless-setup-windows10-rndis-driver-issue-resolved/
Then, the most important step to get any connection at all is to give the new network interface called usb0 on the RaspberryPi Zero a fixed IP configuration. Otherwise, the interface won't come up and Windows might show the Ethernet device but without a cable plugged in.
Open /etc/network/interfaces
sudo nano /etc/network/interfaces
and at the bottom, add
allow-hotplug usb0
iface usb0 inet static
        address 192.168.7.2
        netmask 255.255.255.0
        network 192.168.7.0
        broadcast 192.168.7.255
        gateway 192.168.7.1
Then restart the interface to activate the new configuration
sudo ifdown usb0
sudo ifup usb0
ifconfig usb0
Now, it is wise to also give your new network interface on the host computer a static IP. I chose
192.168.7.3
If you want you can also bridge the network interfaces to the host's internet connection by following the rest of the Adafruit guide. But I simply configured the Raspberry Pi's wifi for now.
https://learn.adafruit.com/turning-your-raspberry-pi-zero-into-a-usb-gadget/ethernet-gadget
View project log
