Hello again hackers!
I come bearing good news about the universal remote aspect of OpenMote! After 4 hours of bug fixing and chasing a corrupt platformio file I am happy to announce that OpenMote is fully compatible with Esphome and by extension Home assistant! I've provided a lovely gif showing the wireless and automation features of OpenMote!
https://drive.google.com/file/d/1KpuRrlwi4Olt1J8T5HpseYAywZVrz9lH/view?usp=sharing (sorry for the link can't figure out how to attach a gif or webp...)
In this demo OpenMote is Connecting to a home Wifi Network, sending MQTT calls to another esp32s3 and has full OTA (over the air updating) functionality.
I'm quite proud of the universality of OpenMote and am excited to see what everyone is able to build and control with it!
Tune in and follow this project as next update will be about Bluetooth keyboards and the possibilities that this opens up for OpenMote to control not just your computer but even your phone!?
I've attached the YAML file for OpenMote and the Light in this post so check it out if you want to replicate my project, you'll just have to switch keys for your own configurations.
esphome:
friendly_name: Light
esp32:
board: esp32-s3-devkitc-1
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: ""
ota:
- platform: esphome
password: ""
wifi:
ssid: !secret wifi_ssid
password: !secret wifi_password
# Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: "Light Fallback Hotspot"
password: ""
mqtt:
broker: # 👈 MUST be your computer’s local IP
port: 1883
discovery: false
# Listen for commands from the remote
on_message:
# Toggle command for the A button
- topic: light_strip/command/toggle
then:
- light.toggle: my_led_strip
# Next Color command for Button 1
- topic: light_strip/command/color_up
then:
- lambda: |-
static const std::vector<Color> colors = {
Color(255, 0, 0), // Red
Color(255, 165, 0), // Orange
Color(255, 255, 0), // Yellow
Color(0, 255, 0), // Green
Color(0, 0, 255), // Blue
Color(75, 0, 130), // Indigo
Color(238, 130, 238),// Violet
Color(255, 255, 255) // White
id(color_index) = (id(color_index) + 1) % colors.size();
auto new_color = colors[id(color_index)];
auto call = id(my_led_strip).turn_on();
// ✅ CORRECTED LINE: Pass the R, G, and B components separately.
call.set_rgb(new_color.r / 255.0f, new_color.g / 255.0f, new_color.b / 255.0f);
call.perform();
# Previous Color command for Button 2
- topic: light_strip/command/color_down
then:
- lambda: |-
id(color_index)--;
if (id(color_index) < 0) {
id(color_index) = colors.size() - 1;
call.perform();
# A global variable to keep track of which color is currently selected
globals:
- id: color_index
type: int
restore_value: no
initial_value: '0'
# Define the LED strip
light:
- platform: fastled_clockless
pin: GPIO8
num_leds: 86
chipset: WS2812B
rgb_order: GRB
captive_portal:
esphome:
friendly_name: openmote
esp32:
variant: ESP32S3
framework:
type: arduino
# Enable logging
logger:
mqtt:
broker: xxx.xxx.x.xxx # 👈 replace with your computer’s local IP or your MQTT server's IP
port: 1883
discovery: false
ssl: false
api:
encryption:
key: "" #replace with your own Key!
ota:
- platform: esphome
password: "" #replace with your own Key!
wifi:
ap:
ssid: "Openmote Fallback Hotspot"
binary_sensor:
- platform: gpio
pin:
number: GPIO14
mode: INPUT_PULLUP
inverted: True
on_press:
- mqtt.publish:
payload: "TOGGLE"
- platform: gpio
name: "Button 1 (Next Color)"
pin:
number: GPIO37
mode: INPUT_PULLUP
inverted: True
on_press:
- mqtt.publish:
payload: "UP"
- platform: gpio
name: "Button 2 (Previous Color)"
pin:
number: GPIO38
mode: INPUT_PULLUP
inverted: True
on_press:
- mqtt.publish:
payload: "DOWN"
captive_portal:
Gangwa Labs
