DIY Dive SONAR using Open Echo
A project log for a DIY open-source SONAR
Development of an open-source SONAR, echo sounder, fish finder using standard, easy-to-source components. DIYable and hackable.
jan-neumannJan Neumann 07/14/2025 at 18:240 Comments
I built a working dive SONAR using Open Echo.
This lets you "see" in water with low visibility and has a range of at least 25m. (couldn't test further)
I is CNC machined from a big block of PE, runs on a raspberryPi, 7" screen and the All-In-One development hardware of Open Echo.
