![](https://cdn.hackaday.io/images/9856041720482434635.jpg)
![](https://cdn.hackaday.io/images/6898271720482434638.jpg)
![](https://cdn.hackaday.io/images/2718021720482716426.jpg)
Upon further inspection, the original intake cap wasn't a filter but a spring loaded valve. It closed when the tube wasn't connected. When the tube was connected, it pressed in a spring loaded plunger to open the valve. A small groove allowed fluid to flow out of the valve.
A lower o-ring was the one that cut off the fluid flow. An upper o-ring was supposed to form a seal against the tube. It seemed to be another source of easy air leaks that could require lubrication. The lower o-ring was not user serviceable.
Your best bet is to scrap the intake cap but keep the spring. O-rings tend to die in storage, which makes lions wonder how long the pump is going to last.
