EL display and RP2040
Playing around with an industrial monochrome EL display, experimenting with 1-bit rendering, dithering, Doom and TinyGL
Public Chat
By chance, I got myself an industrial ElectroLuminescent(EL) display. It is one bit per pixel monochrome with beautiful amber color (which looks bright yellow on camera) and has a resolution of 320x256.
I was wondering if I could put it to good use, so I started experimenting by driving it with a Raspberry Pi pico.
This project is mostly experiments with this EL display with intention of building something out of it - suggestions are welcome. I'm thinking of a ridiculously looking handheld console that can run Doom and other games.
Being inspired by this excellent article by Surma on image dithering, I started by adapting TinyGL (a well-known OpenGL 1.1-like software 3d graphics renderer) to run on a pico and to render 1-bit dithered images.
I managed make it run and ported some demos such as glxgears and Sproingies from Xscreensaver. Although, it needs a lot of optimization to run smoothly.
The other thing that I've tried so far, is to adapt Graham Sanderson's RP2040 Doom port. This worked out pretty well, I managed to get an acceptable image quality so the game is somewhat playable.
Here is an E1M1 speedrun:
video_2024-08-25_11-19-44.mp4
glxgears on Pico 2 (RP2350)
MPEG-4 Video - 3.40 MB - 08/25/2024 at 09:23
Download
  • 1 × LAEL320.256-6C EL display
  • 1 × Raspberry Pi pico (RP2040)
  • A quick test of Pico 2
    Michael • 08/25/2024 at 09:56 • 1 comment
    A Pico 2 (RP2350) runs glxgears at ~20 FPS without any overclocking. The same demo runs at about 12 FPS on an RP2040 overclocked to 270 MHz, and at about 5-6 FPS without overclocking.
View project log
LCLDIY wrote 06/03/2025 at 13:50 • point
Hello, thank you. May I ask if you can open source this project, the code and the circuit diagram
Michael wrote 06/13/2025 at 14:17 • point
Hi, please check the github links - the source code is all there.
Chris Combs wrote 07/24/2024 at 03:46 • point
So cool!! Thanks very much for sharing this project!
I was inspired to get a couple of these displays too... one detail is eluding me, what voltage did you end up providing to the dc-dc input?  12v? Thanks for any advice you can offer!
Michael wrote 07/24/2024 at 13:44 • point
Yes it works from 12V DC, although I've found that it can be as low as 9V - it doesn't seem to affect performance.
Chris Combs wrote 07/24/2024 at 13:54 • point
Thank you so much!
Muth wrote 07/14/2024 at 09:38 • point
Nice project!
A long time ago I managed to get "2 grayscales" on a planar EL.320.240 by alternating two frame buffers at 100Hz, in addition to ordered dithering. But I used an fpga and an hdmi interface. https://www.youtube.com/watch?v=7yBfuNI2T2Q
Michael Waiblinger wrote 07/10/2024 at 10:22 • point
Did you put Lena's hat on Freddy's head? Amazing, where is the source? Love the Display btw.
Michael wrote 07/10/2024 at 14:17 • point
It's "Ethically sourced Lena" - https://mortenhannemose.github.io/lena/
Michael Waiblinger wrote 07/10/2024 at 15:13 • point
Damn, I accidentally ... the whole rabbit hole, all at once.
But you must admit in low-res he really resembles Freddy here.
Boris Bershadsky wrote 07/09/2024 at 13:26 • point
This looks incredible, where did you source your display? Looks like out of stock or discontinued. It would be cool to have an array of these for monitoring stocks
Michael wrote 07/09/2024 at 19:04 • point
I got it from ebay, from a Canadian seller. However, they listed it as a TFT LCD, which is not quite true, but I'm not complaining :)
