I just printed a couple of parts to quickly try everything together.
![](https://cdn.hackaday.io/images/1623581724793365835.jpg)
The hardest part was to glue the seal to the housing. The seal is made of silicon rubber which does not really adhere to anything. But finally, using some silicon-base adhesive I managed to quickly test things together.
