USB Microwave Generator
25...6000 MHz
Specifications
— frequency Range 25...6000 MHz, if is a chip HMC833;
— Frequency range 25...3000 MHz, if is a chip HMC830;
— Adjustment of signal power, 31.5 dB, step 0.5 dB;
— Precision setting of the frequency ~10 Hz;
— The maximum measured signal power at 1 GHz – 17 dBm;
— The maximum measured signal power at a frequency of 2 GHz 16 dBm;
— The maximum measured signal power at 3 GHz and 12 dBm;
— Power and control - microUSB.
GOAT INDUSTRIES wrote 02/27/2017 at 10:40 point
I click on 'Details' and there seems to be nothing there?
Denis Barinov wrote 02/27/2017 at 11:29 point
all the files here, on github -> http://dropmefiles.com/XjV61
Frank Buss wrote 02/03/2017 at 06:35 point
Okay, so how is this Sci-Fi themed?
Denis Barinov wrote 02/03/2017 at 08:07 point
This is a real working device.
