Hackaday.io Hackaday.io
Sign up Log in
SmartClick: A Single Button for Power and Input
This breakout enables you to use a single button to power on and off your project while also using the same button as user input!
bare-naked-embeddedBare Naked Embedded
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
124
0
0
0
Team (1)
  • bare-naked-embeddedBare Naked Embedded
Join this project's team
  • SmartClick
hardware
ongoing project
STM on off controller LiPo adafruit power ui
This project was created on 07/10/2024 and last updated 2 years ago.
Description
This breakout is based on the STM326601 on/off controller which allows for the use of a single button to power and control any project. This keeps the UI simplistic saves space.
The first button press will wake up the controller and enable a 3.3V output. Any button presses after that will trigger an interrupt signal and a long button press will disable the 3.3V output and put the controller back to sleep.
This breakout can handle all your power needs with a 500mA 3.3V output, standard JST battery connector, 100mA single cell battery charger and battery level indication.
Details
Log In/Sign up to comment
Sign up with Github
OR
JLCPCB: This solution is about the wireless electric toothbrush. If the BOM list needs, please leave a message.
Project Owner Contributor
Wireless Electric Toothbrush Solution by JLCPCB
catherine-suiCatherine Sui
Automatic Turn On After Power Up for Teufel Audio Receiver and Subwoofer
Audio Receiver & Subwoofer - Auto On
doubleyouDoubleyou
Use a processor to press remote keys
Controlled remote
oaolsenO.A.Olsen
10,000 BC Unga Bunga game controller, using stones and stick!
UNGA BUNGA CONTROLLER
tinandjartinandjar
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "SmartClick: A Single Button for Power and Input", please tell us the reason.
Send message
Remove Member
