Pause for Supercon
A project log for Core64 and Neon Pixels Controlled with 65uino
A fusion of three Hackaday projects controlled by a 6502!
andy-geppertAndy Geppert 09/17/2024 at 13:160 Comments
This project is pausing through the end of 2025 because I am sending in the Core64+Neon Pixels demo to be displayed:
https://hackaday.com/2024/08/26/supercon-2024-show-off-your-unique-display-tech/
The next phase of the project is to build the big-banging required to drive the Serial Shift Registers. That should relatively straightforward since it's not much different than the code to drive the Neon Pixels.
