Electric Imp Explorer Office Sensor Hub
A beautiful marriage between cloud and physical device that makes large scale IoT deployments very easy.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
I’ve raved about Electric Imp before – I pretty much suggest getting one just to experience the magical way that you program it.
What is Electric Imp, you ask? It’s a beautiful marriage between cloud and physical device that makes large scale IoT deployments very easy. Even better – it’s cheap. The particular breakout board I’ll be going over how to use comes with temperature, humidity, pressure, and gyroscopic sensors built-in in addition to 4 Grove connector pins for even more plug-and-play sensors.
With the ImpExplorer, I set up an entire office monitoring hub for $40. And, excluding some code troubleshooting, the entire thing was up and running in less than an hour.
Project level: Beginner
Approximate time to complete: 45 Minutes
Side benefit: Ending your files ".nut"
In this step-by-step tutorial, you will:
To continue, please go to:
