Overview
The garage door opener remote control stopped working. I decided to replace it with an Android app on my phone. I wrote a little piece of code that runs on a Raspberry PI Pico using MicroPython that opens the door. It communicates with the app using Bluetooth Low Energy (BLE).
I chose the PI Pico because I had one on hand when I started the project. It was cheap so I had bought one to play with previously. It also had BLE capabilities. It didn’t need to be low powered as it would always be plugged in. Also, I wanted the chance to try out programming a microcontroller with Python.
I did not want the opener to have a Wifi or cloud component. It might have been cool to open the garage remotely, but it’s not at all necessary - in fact counterproductive. I only need to operate it when I’m sitting in the driveway.
Materials
DC 1 Channel Optocoupler 3V/3.3V Relay High Level Driver Module Isolated Drive Control Board 3V/3.3V Relay Module for Arduino https://www.amazon.com/gp/product/B07XGZSYJV
Raspberry PI Pico https://www.raspberrypi.com/products/raspberry-pi-pico/
Takeout container to put it in: https://www.amazon.com/YW-YSD-2532-12-Plastic-Soup-Container/dp/B06Y6JWQTD?th=1 I recycled one I already had on hand.
Garage Door Opener
The garage door opener is an older model that has a wired switch near the door as well as the remote control. After a bit of online research and testing, I confirmed that all I needed to do to trigger the door to open or close was to momentarily complete the circuit between the two terminals on the opener.
To avoid frying the microcontroller, I used a relay between the GPIO pins on the Pico and the Garage to complete the circuit. As wikipedia describes, a relay is an electrically powered switch.
The opener doesn’t have any logic to know if the door is open or closed. When the switch activates, the garage door opens or closes, or if it’s currently moving, it stops. I’ve never looked at the hardware, but I expect it’s just a question of what direction the motor turns, governed by some limit switches which stop the motor and reverse the direction next time it starts.
Microcontroller Circuit
Connect the Pi Pico to USB for power and connect one terminal of the relay to Pin 16 and the other to ground. Connect the output connectors on the relay to terminals 1 and 2 of the garage opener.
When the GPIO pin is set high, the relay turns on and completes the circuit on the opener side, activating the garage door. It only has to turn on for a short time to start the garage door motor.
Microcontroller code
I’m using the BLE advertising example to do the BLE magic. You can find the code here: https://github.com/micropython/micropython/blob/master/examples/bluetooth/ble_advertising.py
My code sets it up and defines an interrupt callback that is triggered when serial input is received. It just looks for the word “Open” coming in and then calls the routine to open/close the door. See A Note About Security below if this triggers your security intuition.
def start():
led_onboard = Pin("LED", Pin.OUT)
ble = bluetooth.BLE()
p = BLESimplePeripheral(ble)
def on_rx(v):
print("RX", v)
if b'DoorOpen' in v:
OpenDoor()
def OpenDoor():
print("Opening...")
relayPin = Pin(16, Pin.OUT)
relayPin.value(0) # make sure it's off
relayPin.value(1) # turn it on
time.sleep(.5) # wait a very short time
relayPin.value(0) #turn it back on
print("done")
You can find the complete code here.
Packaging
The thing I struggle with the most with these microcontroller projects is how to put them in a finished box. In this case, since it was going to sit in the rafters of my garage, it didn’t have to be pretty.
For this project, I put the relay, Pi Pico, and connecting wires in a well washed plastic takeout container that previously contained green thai curry. I punched a hole in the container to fish the control wires to the garage door opener and the USB cable to power the gizmo.
Android App
I spent considerable time using Android Studio tutorials to build the app part of this build. I built a simple app with a button and could call code when the button was pushed. However, I was stuck on getting Bluetooth working.
Eventually I found an easier way using a no-code/low-code platform https://appinventor.mit.edu the MIT app inventor - a “no code” android app studio, plus an example on how to do it. https://www.youtube.com/watch?v=RvbWl8rZOoQ
The “code” is snapped together from components. It’s a pretty neat setup for writing code without writing code. For me, I think it would have been easier to just write code, but I see the appeal for someone who’s new to programming.
I hardcoded the Pico’s MAC address to avoid needing logic to figure out which device to connect to.
When the button is pressed, it connects to the PI Pico via BLE, and sends the word “Open”. The Pico will accept the connection, and then trigger the door to be opened.
In practice, it has been reliable. It may take a second or two for the connection to be made and the door to start.
The project files are also in the github repo. The .AIA and .APK are zip archives, if you want to poke around and see what this app builder actually stores.
I did not put a lot of thought into the security of this setup. After the fact I thought about implementing rolling codes using something like https://pyauth.github.io/pyotp/,
The fixed string that I did implement has terrible security. Anyone nearby could snoop the string and open my garage.
However, the remote control I’m replacing is from the 1980s or ‘90s. I would bet it has no real security either and uses it’s own fixed signal. There’s probably a small number of signals that will open any garage door from the same manufacturer.
Then again, my garage has windows and a side door. It would be far easier to smash a window, get into the garage than to intercept/decode the bluetooth signal. This is not a high security garage.
