Everything available on the linked Github Repo.
An E-paper digital clock that updates the time seamlessly, while using very little power
U8g2_for_Adafruit_GFX-master.zipArduino LibraryZip Archive - 9.28 MB - 07/19/2024 at 05:43 |
GxEPD2-master.zipArduino LibraryZip Archive - 4.28 MB - 07/19/2024 at 05:43 |
Case.stl3D print fileStandard Tesselated Geometry - 109.07 kB - 07/19/2024 at 05:43 |
Combined.3mf3D print file3mf - 176.22 kB - 07/19/2024 at 05:43 |
Back.stl3D print fileStandard Tesselated Geometry - 41.68 kB - 07/19/2024 at 05:43 |
Arduino | E-paper Display | RTC unit | Buttons |
5V | VSYS | ||
3V3 | Vcc | ||
GND | GND | GND | All buttons bottom right pin |
A4 | SDA | ||
A5 | SCL | ||
D2 | INT | ||
D3 | Button 1 bottom left pin (Down) | ||
D4 | Button 2 bottom left pin (Change function from changing hours to changing minutes to exit changing time mode) | ||
D5 | Button 3 bottom left pin (Turn on changing time mode) | ||
D6 | DC | ||
D7 | BUSY | ||
D8 | Button 4 bottom right pin (Up) | ||
D9 | RST | ||
D10 | CS | ||
D11 | DIN | ||
D13 | CLK | CLK |
//rtc.setTime(sec, minute, hour, day, date, month, year); //USE THIS TO INITALLY SET TIME. Once set it needs to be commented out so that it doesn't get set to this time every restart
cpknight
Henry York
Simon
clewsy
What a great project! Could you view my message?Thanks
