This project came about when I came across this project (Hackaday writeup), where the creator made a one-pixel camera out of an IR sensor and an Arduino.  Because the sensor acted as a single pixel, he mounted it on two servos and assembled a picture by scanning it in the X-Y axis.
My version is a little different:
But first...how does it look?
On the left is a picture on a sunny day on my front porch; on the right is a picture taken with my phone.  The scene is definitely recognizable, but doesn't seem as detailed as the original creator got with his.  It takes 7.5 minutes to take a 90 pixel by 90 pixel image.
The Imager
The imager is a dirt-simple pinhole camera. Its sensor is a random photoresistor.  I had missed the part of the original writeup where the IR sensor was mentioned; I'm not sure if that's why I'm seeing the difference in quality in my pictures, but it's clear that the original pictures are much nicer than I've been able to achieve.
I've mounted it on a bit of prototype board; I covered the back with electrical tape to shield the sensor from stray light.  I've hot-glued a length of cardboard tube from some paper towels to the board, then covered the end with aluminum foil.  I poked a hole about 2mm across.  Side note: having the pinhole, instead of leaving the end uncovered, was an incredible improvement in image quality.  I knew pinhole cameras were a thing, but the difference was truly shocking.
The resistor is fed with 3.3V from the ESP32, and I'm reading the drop in voltage with one of the ESP32's analog sensors.  I'm doing this in 16-bit mode, which is overkill and useless.  The voltage varies enough that I read 10 samples and average them in order to try and keep things reasonably constant.
The platform
The platform is more cardboard, plus hot glue and zip ties.  I've done some amateur astronomy, so what I had in mind was a simple alt-az mount.  The tube is zip tied to the horn of an SG90 servo, which moves in the Y direction -- the altitude part of an alt-az mount.  The SG90 turned out to be rather weak, but it had enough power to do this.
The S90 is mounted in a short length of the same cardboard tube used for the sensor; it fit just right, so I didn't have to use any hot glue there.  The azimuth mount is a cardboard tube from a roll of toilet paper, and the altitude mount is hot-glued to the top.  This tube also serves as the mount for the protoboard that connects the photodiode and the altitude servo to the ESP32.  The protoboard was scrap from another project, but it had some nice header pins already in place and works well.  It's held in place with a zip tie.
The bottom is a disk of what I've learned is called mat board; I picked a random waiting-to-be-reused gift box to do this with, and I'm now in love with the stuff.  On the bottom of that are three pairs of magnets, wrapped in different colours of shrinkwrap tubing and hot-glued in place.  These mate with ones with matching colours on the base (more on that in a sec); having an easy way to remove and replace the camera is incredibly handy.
The base
The base was made by my father-in-law out of scrap wood.  He's a retired millwright who loves collaborating on these projects, and has a garage and all the tools you need to rebuild civilization -- so he's a great ally to have.  In the base's vertical component is a Tower TG90 servo, which rotates in the Y axis -- the azimuth part of an alt-az mount.  Originally I'd tried using an SG90 for this, but it didn't have the strength to rotate the lid.  (Side note: I also got confused when ordering the replacement servos...it turns out a "360 degree servo" is just a continuous rotation motor, not a servo that can go to any angle between 0 and 360 degrees.  🤦)
Mounted to the azimuth servo is a plastic peanut butter jar lid, held in place with a random thumbscrew from the junk drawer.  The magnets I mentioned above glom on to the platform.
The base's horizontal component has mounting holes for the screws that act as legs for the electronics board.  Speaking of which...
The electronics board
The electronics board is a small piece of prototype board.  I've put in header pins for the ESP32, and drilled mounting holes for the PWM controller.
The controller is a PCA9685; I'm only using two channels, but it's very handy.  I've got a separate power supply for it, hanging off the side.  (Side note: oh my god, if you're having any problems with servos, swap out the power supply and try something else.  I had no end of erratic behaviour until I got a new supply that could do 2 Amps at 5 Volts.)
The photoresistor in the sensor is connected to the ESP32 through a 5K potentiometer.  I was hoping that this would let me adjust the sensitivity for dim or bright scenes, but it hasn't been as useful as I'd hoped.
The code
The code for this project can be found here (Gitlab mirror).
The ESP32 is my second-favourite platform after the Pi Pico, and MicroPython is definitely my favourite language.  I can write C++ for Arduino stuff, but mainly by copy-pasta.  I'm much more familiar with Python, and it's an absolutely perfect fit for my brain.
The code on the microcontroller is pretty simple: there's a library for the PCA9685, then some code I wrote to swing the servos around as needed and take readings.  The altitude arm moves the imager from top to bottom, stopping at one degree increments to take readings.  When it reaches the bottom, the azimuth arm turns by one degree, then the altitude servo swings the imager back up before scanning down again.  (Originally I had it scanning in both directions, but for some reason the resulting image was quite jagged -- the match between adjacent columns was quite terrible.) I'm sure the movement isn't exactly one degree, and I can see at least some points where the azimuth servo just doesn't seem to rotate at all, but so far it seems to be working well enough.  The data is just printed to the serial port (ie, the USB cable) connected to my laptop.
The laptop, meanwhile, is running the capture code and the image processing code (such as it is); Pandas, numpy and Matplotlib are used heavily.  The capture code reads the data from the serial port; when the camera signals it's done, the data is written to file in CSV format.  (Writing out actual image files is on the TODO list.) After that, the image is displayed along with some semi-useful histograms.
It doesn't take much to max out the camera, so I clamp the data to a normal distribution to try and bring out details that might otherwise get lost; it's definitely an improvement, as you can see here:
(This is the same picture as is at the top of this article.)
In addition to clamping the data, I also use bicubic interpolation on the pixels to smooth out the edges; that's what takes away the pixellated look from the original.
The result of all this is a 90 x 90 pixel greyscale image with heavy distortion, unexplainable streaks, and terrible dynamic range.  I love it!
Shortcomings, accusations and TODOs
