New features added:
- Three grid helper added in threeJS view.
- Changed axis colors in threeJS view to fit according to printer.
- Show electrode option in threeJS view and change diameter on it.
- Moving electrode forward based in estimations and do stop and back based in realtime.
- Allowing Invert print direction (print file mode)
- Allowing down electrode without change XYZ (to feed worn out electrode in print file mode)
- Reset XYZ button.
- Showing voltage values. (Added OPAMP in schematic for ADC pin)
- Relay to avoid positive electrode has dangerous voltage when IGBT is in off mode.
- Led connected to relay to dischage capacitor when IGBT is in off mode and to advise the electrode has voltage.
Next::
- Allow import file from a Blender scene with a line path.
