The following items were successfully set up and or installed:
- Wind Turbine
- Invertor
- Battery
- Battery Box/ Power Station
The below items were successfully tested and running as expected:
- Battery
Next Steps
- Anderson Power Connections need to be installed and hooked up from the wind turbine to the Wind controller
- Assess if any additional tools are needed to mount the Wind turbine on the repurposed flag pool
- Measure out suitable wire to run approximately 15 feet of wire from wind controller to Power Supply input
