Outstanding Items from my last log
- Anderson Power Connections need to be installed and hooked up from the wind turbine to the Wind controller
- Assess if any additional tools are needed to mount the Wind turbine on the repurposed flag pool
- Measure out suitable wire to run approximately 15 feet of wire from wind controller to Power Supply input
Actions Taken and Updates
1. Anderson Power Connections Installation:
- Components Ordered:
- 175A Battery Connector for 175A 600V Plug, Quick-Connector Disconnector Housing 2-Pole (Red, 4 AWG):
- Reason: These connectors are high-current capable and provide a quick disconnect feature, making maintenance and installation easier.
- MJPOWER Anderson-to-8mm Extension Cable 10FT/3m 14AWG Wire 8mm DC Power Plug Adapter:
- Reason: Provides flexibility in connecting various components and extends the reach of the Anderson connectors.
- JooFn 175A Plug Mounting Panel with Cover for Anderson SB175 Connectors Flush Mount Recessed Plate (Red-1pc):
- Reason: To ensure a secure and professional mounting of the Anderson connectors on the panel.
- Action Taken:
- Anderson connectors will be installed to facilitate easy connections and disconnections between the wind turbine and the wind controller.
2. Tools for Mounting Wind Turbine:
- Assessment:
- No additional tools were identified as necessary after reviewing the mounting requirements for the repurposed flag pole.
- Update:
- The current tools are deemed sufficient for mounting the wind turbine. Adjustments will be made based on the specific installation process.
3. Wire Measurement and Installation:
- 4 AWG Battery Cable 4AWG Gauge Pure Copper Battery Inverter Cables with 3/8 in Lugs Both Ends Power Inverter Wire Set (9in):
- Reason: Ensures minimal resistance and efficient power transfer over short distances.
- 4 Gauge 4 AWG 20 Feet Red + 20 Feet Black (40 Feet Total) Welding Battery Pure Copper Flexible Cable Wire:
- Reason: Provides the necessary length and flexibility to connect from the wind controller to the power supply input.
- TKDMR and Sanuke Wire Lugs Ring Terminal Connectors Ends Heavy Duty for Battery Cable Lug Wire Electrical Eyelets with 3:1 Dual Wall Adhesive Heat Shrink:
- Reason: To ensure secure and durable connections at the terminals.
- Action Taken:
- Measured and prepared the 15 feet of wire required for the connection from the wind controller to the power supply input.
- Selected 4 AWG wire to handle the current capacity and minimize voltage drop.
Update:
- (My buddy offered me and allowed me to pick up some solar panels, resulting in this beneficial upgrade to the project. Solar Panel Integration) (Change and Unintended Upgrade):
- Thunderbolt Magnum Solar 100 Watt Solar Panel Kit:
- Reason: To provide an additional renewable energy source for charging the battery, complementing the wind turbine setup. I will not use the solar controller as it needs to be powered and hook the Solar DC connection to an adaptor that will connect to my Adderson input/output connect.
Additional Components and Their Purposes:
- Cordless Heat Gun:
- Reason: For shrinking heat shrink tubing on connections, ensuring they are insulated and protected from environmental factors.
- LeMotech Junction Box:
- Reason: To house and protect electrical connections, ensuring they are kept safe from dust and moisture.
- VenxyKod Bus Bar 5/16" Power Distribution Block 250A 12V Terminal Block 4 Studs Junction Block with Cover:
- Reason: For efficient distribution of power and organization of connections, providing a clean and safe installation.
- ANDERSON POWER PRODUCTS 111038G2 INSERTION EXTRACTION TOOL:
- Reason: To facilitate easy insertion and extraction of Anderson connectors, ensuring secure and reliable connections.
Summary:
- Anderson Power Connections: Components ordered and ready for installation.
- Tools for Mounting Wind Turbine: Current tools are sufficient.
- Wire Measurement: 4 AWG wire measured and prepared for the required 15-foot run.
- Solar Panel Integration: Solar panel kit ordered and ready for integration as a beneficial upgrade.
The components were chosen to ensure a robust, flexible, and secure setup for the wind turbine power station. The selected items provide high current capacity, easy installation, and weather protection, ensuring the system's reliability and longevity.
