Lower Section of Pole Secured
A project log for Power Up Off-Grid with Bougie Bro
A practical guide to building an off-grid power station using wind energy, suitable for off-grid applications and backup power options
bougie-broBougie Bro 08/13/2024 at 06:470 Comments
The pole was unscrewed allowing me to secure the lower section to the ground. I used a Green Concrete mix that was designed for my region. However, different areas and climates may need a different recipe.
My Green Concrete recipe.
I ordered the wrong size Anderson connections. My system needs SB50 which is designed for 50 volts.  The replacements are on the way
