A Solid State Tesla Coil (SSTC) is a type of Tesla coil that uses solid-state components such as transistors, diodes, and capacitors to generate high-voltage, high-frequency alternating current electricity. They have higher efficiency, the possibility of long-term work, as well as compact dimensions. SSTCs come in various types and designs, each with its own characteristics and applications. This time I will describe to you how to make a Tesla coil that works in the so-called class-E, which in addition to being simple and cheap to make, it is also very efficient if is well adjusted. The original design is by Richie Brunett followed by several versions including that of Stevie Wards ), which uses Antenna feedback, and PLL. I decided to make the LabCoatz version, based around an adjustable Schmitt trigger oscillator with a range of 100kHz-5MHz.
![](https://cdn.hackaday.io/images/3783221721987215421.jpg)
And as usual, I adapted the project based on the materials I had at the moment, and at the same time simplified it considerably. However, the end result is excellent and with a voltage of 70V - 90V the length of the sparks is 15 to 20cm, which is significantly more than the one in the original project. Due to the fact that I did not use an interrupter, in this case there is no option for an audio modulator, which is also conditioned by the cheap mosfet driver IC TC426.
And similar to any tesla coil, the basic parts are the primary and secondary coils. In this particular case, the primary consists of 20 windings of copper wire with a diameter of 2.5 mm wound on a plastic cylinder with a diameter of 11 cm. The secondary contains 1300 windings of insulated copper wire on a plastic body with a diameter of 7cm and a height of 20cm. The diameter of this wire is 0.14 mm. The calculated resonant frequency of the secondary together with top load is about 260KHz, and in practice somewhat higher.
![](https://cdn.hackaday.io/images/3480951721987289067.jpg)
This project is sponsored by PCBway. This year PCBway is celebrating the 10th anniversary of its successful existence. On the occasion of this event, PCBway provided its users with more conveniences such as big savings for certain products, as well as discounts of up to 80%. From July 1st to July 31st, log in to the PCBway site, and start the PCBway 10th Anniversary Tour, where you will enjoy Coupons, Lucky Draw, Exclusive Badges, unboxing blind boxes, and many other surprises.PCBway is always your great choice.
![](https://cdn.hackaday.io/images/4128351721987397213.png)
The drive part consists of several components:
- adjustable Schmitt trigger oscillator with a range of 50kHz-2.5MHz made with 74HC14 hex inverter IC.
- tp267 cheap mosfet driver IC.
- Powerful mosfet I used IRFZ, but it is better to use more powerful IRFP460.
- a polypropylene capacitor with a capacity of 1 nf or more depending on the tuning.
- 7805 CMOS IC power supply stabilizer
- 12V power supply for the oscillator and mosfet driver,
- and to power the mosfet and the primary coil, instead of full wave I use a half wave single diode power supply with a small 1µF filter capacitor primarily due to the fact that I could not use an interrupter due to the lack of an Enable pin on the mosfet driver IC.
![](https://cdn.hackaday.io/images/4478751721991850262.jpg)
If you want to ideally adjust the Tesla coil, you definitely need a two-channel oscilloscope and a lot of patience. The setup method is explained in detail on the original project page. I will explain the basic setup procedure, assuming we don't have any instrument. First, we apply a voltage of about twenty volts to the mosfet, and with a CFL bulb close to the transformer, we turn the potentiometer until the bulb lights up. We keep spinning until we get maximum intensity.
![](https://cdn.hackaday.io/images/3074051721994326926.jpg)
Next, we change the number of windings of the primary also looking for the highest intensity of the bulb, but we should keep in mind that the number of windings should not be less than 3 or 4 because of the excessive current that can flow through...
