Introduction
This report details the functionalities and components of a Stroopwafel detection system implemented using an Arduino. The system uses various sensors and outputs to detect specific conditions and respond accordingly. The primary components include a temperature sensor (LM35), a DHT11 temperature and humidity sensor, an LCD display, a buzzer, and an LED. Additionally, a linear regression model was used to validate the system's performance through multiple tests. I created a full video on this as well on YouTube where I go through the tests and ideas around the project.
Components and Setup
LCD Display (LiquidCrystal_I2C)
Temperature Sensor (LM35)
DHT11 Sensor
Buzzer
LED
Serial Communication
Code Functionality
Setup Function
Loop Function
Temperature Reading Functions
Music Playback
Serial Message Handling
Testing and Validation
To ensure the accuracy and reliability of the detection system, a linear regression model was employed. The model was used to analyze data collected from multiple tests performed on a YouTube channel. The tests were conducted five times to monitor the system's response to the following conditions:
Temperature Reduction
Serial Message Count
Conclusion
The Stroopwafel detection system is a multifaceted project combining temperature monitoring, user feedback via an LCD, and auditory/visual alerts. The integration of multiple sensors and outputs showcases the capability to create an interactive and responsive system. The core functionality is based on monitoring temperature changes and reacting to external inputs through serial communication, ensuring robust detection and alert mechanisms.
The use of a linear regression model to validate the system's performance adds a layer of reliability. By testing the code five times and analyzing the results, the system's effectiveness in detecting the specified conditions was confirmed. This rigorous testing approach ensures that the Stroopwafel detection system operates accurately and consistently in real-world applications.
