The trigger event is finally recorded at the center of the capture instead of the start. This is achieved using a more complicated PIO program, and a DMA ping pong configuration that creates a ring buffer. Here is an example RC circuit waveform that demonstrates this capability:
![](https://cdn.hackaday.io/images/5480021725055588571.png)
