PatchMate:Level Control Adaptor
Breadboard Compatible and Chip style format synth Adaptars
Starting from
has orders / reviews
Ships from
-Why I made it-
I wanted a good Interface for using common Eurorack 3.5mm Jacks on a standard breadboard. So I made this multi-purpose PCB badge.
It can also be used as a Key-Chain or as a Stand-Alone Volume Level control knob for other 3.5mm /Eurorack Signals like a Volume Knob for CV or Audio Level Voltages. Depends on if its Linear Potentiomter or a Audio one.
Features
*Breadboard Compatible
*Uses common Euro-rack Potentiometers and PJ301/PJ398 Eurorack 3.5mm Jacks
*Dual use Badge as a Input/output Interface for breadboard or as a separate Passive Level Control Adaptor for Euro rack gear.
*Test hooks for looking at Inputs/Outputs
*Male/female 2.54 headers for Input Signals/Ground
*Jumpers to Change between Level Control and IO Connecting the jacks to mono.
View all 3 project logs
