CPLD debugging in-progress
A project log for Digitabulum: The last motion-capture glove
Digitabulum is an open motion-capture glove that was intended to be a full-featured, hacker-friendly user-input and sensor platform.
j-ian-lindsayJ. Ian Lindsay • 06/06/2016 at 06:11•0 Comments
That's the r1 main board with no battery plugged into USB, a logic probe, and the JTAG dongle for the CPLD. The small purple PCB is the debug harness for the digits.
Things that work:
* Buffered clock selection (external vs internal), synchronous reset.
* Basic chip-select functionality
* Tri-state SPI1 CS logic (after some argument).
* Address demux and cycle logic
Broken things:
* IRQ aggregation state machine.
* SPI bus-master behavior is inconsistent.
* Software. Much of the infrastructure is improved, but the logical hook-up to the hardware SPI peripheral isn't there yet.
This is the part of the dev-cycle where two complex systems meet on a strand of copper wire. Getting this piece right will take some more time. But once I've finished, I can give some real-world transfer-rate benchmarks.
Onward....
