Hardware verification for the proposed solution has been completed
A project log for A open-source voice AI assistant
An AI voice assistant that provides continuous audio recording and allows you to integrate any model you want.
%E9%93%B2%E5%B1%8E%E5%B0%86%E5%86%9B铲屎将军 11/09/2024 at 04:030 Comments
Hardware verification for the proposed solution has been completed. The ESP32-based hardware used for verification has been validated. This verification board can record audio upon button press and stop recording upon release. The recorded data is then sent to a TCP server.
This verification board can now serve as a basic trigger-based voice assistant, although it is still far from our ultimate goal. Attached are photos of the verified hardware solution. The open-source link for the entire project design will be updated shortly, including hardware design, preliminary verification code, and a simple test server code (which merely packages the received audio data into a WAV file).
