Firmware update, PCB layers PDF
A project log for bATtiny Guard - Power Management module
Power management module in a small SMT package with 4+16 ADC channels, 2A battery charger, low on resistance output MOSFET and more
erikedrtechErik@EDrTech 09/06/2024 at 12:370 Comments
A small update to the firmware has been made to make it work properly with revised hardware. A driver MOSFET has been added to improve performance and to invert driving logic of the output MOSFET so it turns on when the uC pin is driven high. This revision also eliminates problems with unpredictable behavior upon connecting the battery and/or module entering UVLO which would cause the output MOSFET to unexpectedly to turn on.
A PDF with all 6 layers of the module PCB has been added to the documentation for easier viewing without unpacking gerber or source files.
Next step is to implement an additional I2C port in firmware to allow the module to act as a master to on-board devices (which it does currently through the hardware I2C) and as a slave to external master. I expect to have this implemented and tested in the next few weeks.
I have been testing the new 0.8mm PCB for about two weeks under load now, and it appears to perform as expected and with excellent stability without issues for the whole duration of testing.
Testing will continue, even tho it probably is proven to work reliably for long periods of time at this point.
