The updated version was just released to fabrication! V0.2 changes include:
- Size reduced (1.5 x 2.0 inches) to comply with the Supercon Add On Contest rules.
- Still requires a badge/host MCU to control the SAO (or use my tiny SAO Demo Controller).
- Added edge-connect option for SAO header mounting.
- Removed some prototype features that aren't needed anymore, simplified pin usage on the IO expander.
- Refined core memory weaving outline and make screen protector easier to install.
- Add I2C address on the front! Still adjustable with solder jumpers on the back.
- Add alternate power input (square pin in the open-end wrench, lower right) to avoid overloading SAO power rail.
- Define tooling pin locations for fabrication.
Andy Geppert
